skid2964
- April 2, 2015
- 2004 Ford Sport Trac
2004 Sport Trac 4x4, 91k miles
Have a road noise, like a buzzing, I have theorized (possibly incorrectly) that I need lower ball joints and this buzzing is coming from the left front tire riding on its edge. I do have noticeably negative camber on that side. So I buy ball joints and lift the truck up to get started but noticed when I spin the driver side wheel, it has more mechanical noise and does not spin quite as freely as the pass side wheel. (I confirmed it is not brake drag).
Now I am assuming I need a wheel bearing assembly. I am here to confirm my thinking before I order more parts.
Also, should my upper control arm bushing mount have play in it? the rear bushing on both sides rattle in the rear mount. The bushing looks good, bolts are tight, but they both rattle slightly.
I am not opposed to replacing all of it, upper arms, lower joints, wheel bearings, tie rod ends..... do ALL these parts wear out quickly on this model?
