jahosha
- May 26, 2010
- Barrie, Ontario Canada
- 2000 LIMITED AWD 5.0HO
I have a front end noise coming from the left front, sounds like a growling like a wheel bearing. It goes away when i turn the wheel left, ive done both bearings prior and took the drivers side bearing off today and its still good. Leads me to believe that it could be the cv shaft on the left side?. The noise does not go away if the trucks in neutral, as long as its rolling the noise is there. Leads me to believe its either the cv shaft or the front diff. The front passenger side axle seal is leaking as well i have replaced them to. I do not think its the driveshaft because it goes away when on a hard left turn. Any help is appreciated
