front end noise!!! | Ford Explorer Forums
front end noise!!!
kzman28
kalamazoo,Mi
2002 explorer sport
Hello while I was driving home from work today.It sounded like I had a bad shock up front while going straight down the road.But when I turned it made a loud squeel sound kind of like metal to metal.sounds louder while turning to the left.But makes the noise either way I turn.Does anybody have any ideas what this could be?It has never had any noises like this!!Could this be the rack.
I would start by inspecting the brakes and wheel bearings.
Brakes look fine.And the truck can be in park and turn the wheels and makes the same noise.So I am thinking it must be somthing in the steering.
sway bar end links are fine.But thanks for the reply!!
check the bushings on the control arm.and all the grease fittings/bushings through out the fron end.
Is the noise in the power steering pump or in the serpentine belt?
Thanks 2000x I think it might be my control arm bushings.:p:
no problem.i have the same noises,well had.its not really there any more because the bushing on the driver side is barely there.but im getting them replaced with polyurathane bushings in about a month when i get my tax return.good luck!
