Front End Question | Ford Explorer Forums
Front End Question
97WHTXLT
Guyton, GA
1997 XLT
I have replaced the upper control arms, shocks and wheel bearings on my 97 XLT 2wd. Also had it aligned. I did all of this after the inside of my tires were getting worn pretty bad. After doing all of that, I also put new tires on it. Now my new tires are wearing pretty bad on the inside. What in the world is causing this? I can't afford to keep messing up tires!
Negative camber - usually need a camber kit to properly align the front tires if the torsion bars have been adjusted lower or are too soft for the current ride height.
Is there a good place to get a camber kit for it?
Not really sure if I found the right thing. Would Moog #K80065 be what I'm looking for?
yes
did you receive a print-out of the before and after specs from the alignment?
maybe they only adjusted toe?
