Front end rebuild | Ford Explorer Forums
Front end rebuild
Catexplorer96
Oklahoma City, Oklahoma
1996 Ford Explorer xlt
1996 xlt 2wd ifs ford explorer. I’ve got a check list for a front end rebuild that im about to do I would like for someone with more experience to recheck this list for me and give me a little of advice or point me in the right thread direction for suspension components
Rough country Shocks
Moog Lower ball joint
Moog inner tie rods
Moog upper control arms
Moog outer tie rod ends
Moog caster shims
Moog sway bar end link
TSS 4” spindles
Am I missing anything?
Sway bar bushings and front bearings
I would do inner tie rods at same time they are always worn out and it is much easier to replace both at the same time because you can simply
Make the new inner and outer assembly exactly the same length as what you removed
96 likely could use new wheel bearings too
Since you are rwd you use regular old style inner and outer bearings and replace the wheel seal on the back of the rotor. Timken or spicer bearings are preferred
