XLimited
- October 10, 2004
- Mohawk, Michigan
- 1993 Limited 4x4
I have a 1993 Explorer with a little over 100,000 I think the front end is starting to sag a little bit. I replaced both shocks up front but the tires are angle out like this / \ I've heard bad springs will cause this, I have really bad tire wear in the inside the alignment is alittle off but not that bad. The ride is pretty crappy up front I feel every bump in the road. The vehical sat for about a year or two with cracked heads. I'm just wondering if there are any sure signs about them and if you have any tips on replacing them. Thank you
