Purethief
- August 19, 2004
- ketchum, ID
- '98 EB
need advice on grinding from the front pasenger side wheel. replaced hub today, noise better but not gone. when turning left the noise gets worse with the body roll. shop says oversized tires the problem. i call BS on that. they also said it is the hub. when the front is jacked up there is play in passenger side wheel.. push/pull one hand on top one on bottom. this slop is not present on the drivers side. looks like it is wiggling at the spindle... you can see the boot wiggle right next to the inside of the wheel. what do i need to replace? halfshaft? cv joint?HELP. searched and read considerable previous posts and they all lean to the hub. what else could it be! 98 AWD EB.
