Tom Wilk
- July 31, 1999
- Chattanooga, TN
- '99 Sport
Well, the front hitch is installed. But, there's one minor problem: I cannot tighten one of the bolts.
Here's the situation. Each side is supported by 3 bolts, two which use the hole that the radiator cover thing was attached to, plus a third that uses the empty hole forward of the other two. The two that used to hold the cover on were already threaded, so there was no problem there. The front hole, however, required using a different technique.
Supplied with the hitch were all the necessary hardware including two flat stock pieces that go inside the frame on the front holes. The nuts for those two bolts (one each side) have a piece of steel wire welded to them so that you can fish the nut into the correct spot to screw the bolt onto it.
Now, the passinger side one tightened up with no problem, but the other one would not tighten. The wire snapped off the nut, and it just spins with the bolt. There's barely enough torque on it to flatten the lockwasher. But, I want it torqued down a little more than that. Does anybody have any ideas as to how I can hold a nut that I cannot get at while I turn the bolt?
I tried wedging a screwdriver against it, but it would not hold. It's in such a position that I can barely get my finger in there to touch it. I'd prefer not drilling any more holes in the frame, unless I have to. But, if that's the only solution, I'll put a slot in there just big enough to get an open end wrench in there to hold the nut.
Any suggestions?
Tom
99 Sport 4x4
SOHC
Auburn Rear & Gerald's old Shackles
265/75-R16 BFG AT's that weren't supposed to fit
Any suggestions?
Tom
99 Sport 4x4
SOHC
