96743explorer
- July 21, 2013
- Big Island, Hawaii
- 06 explorer V6 4x4
so im replacing my front drivers side wheel bearing. took off the brake caliper, pulled off the brake rotor, took off the hub bolt, and took off the 3 bolts holding the hub assembly. now I cant seem to get the damn hub assembly to slip off of the axle shaft. tried hammering it from the back (lol!) with a sledge. tried using a air hammer to the end of the axle shaft. doesn't want to budge at all. do you think I need to buy a hub puller you know the one that clamps on to the hub and pushes the axle shaft out by tightening a shaft?
any help is appreciated. ill be going at it again after work. luckily I have a buddy I can car pool with.
