96eb96
- October 20, 2004
- Albany, NY
- 96 EB V6 OHV 4WD
Where are you putting your jackstands and jack in the front for a safe lift? The frame is tracked by the torsion bars, the bottom of the control arm is an irregular shape, and the tab for the factory jack on the control arm does not look stable. I was thinking either the holes in the front crossmember or under the control arm bushings.
