Front Suspension Bushing Recommendations? | Ford Explorer Forums
massacre
Massachusetts
‘94 Explorer
‘19 Nautilus
Hello,
I am looking for any RA bushing recommendations or brands to avoid etc would be great!
Thank you!
Is the Moog k80007 kit any good? Looks like I would also need to order the heat shields?
I just used the energy suspension set from rockauto.com. I also bought one heat shield for the passenger side. I re-used the washers that were on my rig and added some more at the back so the nut doesnt completely bottom out. It tightened up the steering feel as well as eliminated the vibrations I was having. It's been about a 10k miles now and I've had no issues.
The Moog set looks like what came off of mine and the passenger side was wasted from having no heat shield. I'm sure it would be a fine replacement as long as the heat shield is in place.
Awesome thanks!
Looking on rockauto now, not seeing the ENS bushings
Thank you so much!
Do the stock RA bushings have metal shells that have to be reused? Or am I thinking of the pivot bushings?
Thanks again!
Nvrmnd I was thinking of the pivot bushing. I ordered up those bushings thanks for the recommendation!
