Front Sway Bar | Ford Explorer Forums
Front Sway Bar
kodybud
Flagstaff, AZ
2004 Ford Sport Trac
Does anyone know if they make quick disconnects for the front sway bar? Been searching google and forums and haven't found anything.
Never seen front or rear Explorer end links that were prefabricated. A few have made rears with the use of clevis pins, etc. Fronts differ from the rears being a stem design with stacked load bearing bushings that are highly prone to blowing out. Moog even upgraded their blue thermoplastic rubber front end link bushings to polyurethane for durability. Other issue with front quick disconnects would be keeping them tight enough so they don't rattle and wear out the bushings that contact the LCA's and sway bar eyelets.
http://www.moogproblemsolver.com/_pdf_En/MOOG_PS_Bulletin_25471_K7275_En.pdf
http://www.moogproblemsolver.com/_pdf_en1/MOOG_PS_Bulletin_213006_Sway_Bar_Link_Eng.pdf
