Front Tow Points | Ford Explorer Forums
Front Tow Points
wreck76
Ontario
'09 XLT
Has anyone added front to points to their 4th gen? I imagine that it is not that difficult, but would like to see how some other peoples turned out before i break out the dremel.
This is what I did: used Curtis front hitch to attach my plow brackets, and then I added tow hooks from Chevy S10, and cut out the openings in the air dam.
never thought of a front hitch. thanks for the ideas. :thumbsup:
Does the front hitch reduce ground clearance any? Are there cutouts marked for the tow hooks if I was to purchase the OEM ones and add them?
"Does the front hitch reduce ground clearance any?"
Definitely it does. I do not do any off-roading, and I already had the plow brackets so it did not make any difference to me. I have to watch for high sidewalks when I park front wise.
I do not believe the Gen-4 ever came with tow hooks. I marked mine on the air dam and used dremmel to cut out the openings for the hooks, there is nothing marked behind.
Did you get the hooks from a salvage yard? Also, what did you have to do to mount them?
The hooks are from Chevy S10 and I used steel angles to attach them to the front mount hitch.
I'd like to have hooks. I'll have to crawl under the front end and see where some might be attached without a hitch crossbar. I just saw a 3rd gen on a rack and it had hooks on it.
The OEM ones dont stick out. they are a pain because you have to go under the truck about a foot to hook on to them and the chain pushes up on the air dam when pulling. Kind of a pita.
I thought the OEM tow hooks were actually just the attachment point used during the transport. They are way too deep below.
There is a kit out there, They bolt up to the same points as the bull bar. Have a look at Tasca.
No luck finding the bolt on kit at Tasca. Do you have the item number or keywords?
