front vents not blowing | Ford Explorer Forums
Swanny
Indy, Indiana
'96 Sport 4x4
In my case my vents stopped working after the battery went dead on me and I had to jump it 2 seperate times. I understand on my year this is a vaccuum op. door system. How does the battery going dead effect this?? Anyone?
Swanny
looks like a lot of people have this problem...
EATC or manual control?
Its manual. Update: I checked all vacuum hoses and the black vacuum canister. everything looks ok. I also checked my fuses just in case, they re all good too. I dont know what to do. Its just now getting freezing here too.
Sorry it took so long to get back... The holidays are getting too busy... Does the fan blow any air at all?
No air is blowing from the front vents at all. The fan now blows out the defrost vent near the windshield. I looked at the vacuum lines they are all fine. The thing that gets me is that this only happened after my battery died on me and I had to get a jump. Thanks for any help guys
I think the jump start thing may be just a coincidence... I have 3 ideas of what it could be.
1. Under the blower motor is a resistor pack, about $15 from the dealer, that fails quite frequently. When the pack fails all you will have is the high speed setting. I have also seen total failure of the blower motor. You can see it from the top. It is just below the blower motor. Check and see if it is melted. It may not be but it sometimes is. In some cases you will have to replace the plug too, about $10. It is most easly accesed by the passenger side wheel well by removeing the tire and then all the plastic that is in there. 2 hex screws hold the pack in. I replaced mine and found that the connectors in the plug were corroded. I was able to clean them up.
2. You may have a bad relay. In the battery junction box is a bunch of relays. Swap them around to see if the fan startes to work.
3. A bad control switch. This, I think, is the least likely but possible.
A new switch is about $35 from the dealer. With a multi-meter check the switch for proper operation. Pull the switch and check with a multi-meter.
2 -- __ __ -- 1
4 -- __ __ -- 3
(While holding the switch with the screw hole on top.)
on low none of the connectors should have continuity
on medium-low pins 1 & 2 should show continuity
on medium-high pins 2, 3 & 4 should show continuity
on high pins 1, 2, & 4 should show continuity
There is also a possibality that the GEM was dammaged while jumping the Ex but I highly doubt that...
Hopefully this will give you somthing to go on.
Jeff
they are vacuum motor so i don't think your bttery issue is involved. It probably more likely that your door is stuck in the defrost mode. You need to see if you can move it (gently) or see if it indeed moves when you select that approriate position.
Well when I move it to actual defrost mode i can hear the AC comp. kick in. When the knob is on the front vents position, no AC comp. is working, but it blows out the defrost vent at windshield. I have the next few days off so Im going to get in there and take it apart to look at all the vacuum lines in back. I appreciate all your ideas. Thanks, Swanny
There is definately a vaccum system leak some where. Air through only the defrost is default.
