the piston probably is caught forward at breaking, and then when you let off the pressure, it takes time for the piston to finally slip back into place, since it's lubricated. proves that either the line still has pressure that's slowly returning through a bent hose, or that the caliper piston is actually not going back like it should due to friction. either way, you're lucky your problem is identifiable. pads, also, might be changed when you do the job... (semi metallic is what i'm going for, but thanks guys, for the slider tips).
