kmank
- May 11, 2011
- Danbury, Connecticut
- 1995 XLT
Greetings. Hope all are well.
My problem is with my power steering. About a month ago I blew my drive belt on my 95 Xplorer XLT. I had about a mile or so of getting back home without any power steering. After replacing the belt the steering started acting up. Steering became very unstable and unpredicable. Turning became difficult, had to fight wheel to turn and return to straight again. Auto Zone people told me (over phone) that I may have developed air in lines and to try turning wheel hard left and then right a few times. With no success I bought
and installed a new pump even after they told me it sounded like a rack n pinion problem. After researching r n p problems on the web and after giving mine a pretty good chk for any leaks saw there were none. Well, steering returned to normal somewhat, no more difficulty and wheels seemed
to want to return back to straight after coming out of a turn. I still felt something wasn't completly right. Well, after a month or so the problem has returned, abrubtly. Very Abrubtly.
After reading forums on this type of "stuttering (shuttering?)", hard steering problem I was informed, again, about the air in line prob. So I went and watched the videos about using a hand vacuum pump to remove air. So yesterday I went and purchased all "stuff" needed to construct and
use this method to remove this air. So I flushed out lines again with new fluid and hooked up pump.
Pumped out 20 lbs of vacuum and waited and watched as needle dropped to about 18-17 lbs and stopped there. waited for another 10 mins and then removed pump. Started car (Tires off and off the grnd) and turned wheel. NO CHANGE. Ugh. Still hard and stuttering. Hard lft to hard rght.
Put vac pump on again and tried again, this time when I reached the 17lbs I tried turning the wheels. as I would turn them the gauge would start dropping to 0. When I'd straighten them back out again the vauum would return to 17lbs. ??? Whats goin' on here? When I looked in the pump resevoir the new fluid got darker like the old fluid. I'm very confused here. I'm not quite ready to bring my Xplorer to a garage mechanic if there's something I'm missing to do here and if it is plain old air in the lines. Any help from anyone more knowledgable then me would be really appreciated. If I can get this thing fixed by your advice I will try to give what I can for your time to reply. Thank You. gk
