Bwana Bob
- February 2, 2002
- Morris Plains, NJ
- 92 XLT
I was getting my Explorer fueled the other day when fuel started trickling onto the ground. It looks like its leaking where the fill hose joins the filler neck. I have a good worm gear hose clamp there but the hose has deteriorated above the clamp. It may be that the hose is split or cut under the clamp. I'm going to take a close look at it this weekend.
I priced the fill hose, which, on Fast Parts Network and LMC Truck, is an assembly consisting of the filler neck, fill hose, vent hose and fittings. It is about $330.
Questions:
1) Is there enough slack in the fill hose for me to cut off the bad couple of inches and reconnect it to the filler neck?
2) Is the hose a standard size, so that I could just buy new hose by the foot at an auto parts store and cut it to length? Is heater hose resistant to gasoline?
3) I'm going to crawl underneath, but does anyone know if the fill hose can be replaced without dropping the tank? The pictures in my service books do not show a rear shield around the tank.
4) Would it be a bad idea to cut off the bad end of the hose and connect a short piece of new hose or one of those neoprene pipe couplings inline, perhaps joining the two hose sections with clamps and a piece of plastic pipe?
Thanks.
Bwana Bob
Questions:
Thanks.
Bwana Bob
