Did your keurig get recalled?
I could never understand why a 39c strainer isn't included-esp. when the warranty explicitly notes that you must replace it to validate the warrantyFYI: My new Bosch fuel pump arrived today. Installed it in the fuel pump assembly. Pump was identical to OE in every way. Fit perfectly and everything needed (other than the strainer) was in the box.
Bill
Yeah I'll pry order the Bosch and Airtex strainer, can get both on Amazon Prime for like 68 bucks and two day shippingFYI: My new Bosch fuel pump arrived today. Installed it in the fuel pump assembly. Pump was identical to OE in every way. Fit perfectly and everything needed (other than the strainer) was in the box. Couldn't be happier with it.
The China Freight fuel pressure tester will pay for itself the first time you use it. I stubbornly chased a stumble and hard start in my V6 Mustang before finally buying the fuel tester and-whaddaya know- 15 lb pressure. New Spectrum pump and the problems all vanished.
Bill
I like Bosch products, just not their spark plugs.
I loved Bosch parts so I started using their plugs, they were supposed to handle 3 heat ranges which (unbelievably!) was perfect for an engine I had.
Crap!
I'm now an NGK (Iridium) fanboy.
Is it safe to love Bosch again?
Yes, just don't use their spark plugs in Fords.
Just lean codes-P0171 and P0174, but my fuel trim readings were leading me to believe it was either a vacuum leak or a faulty O2 sensor. Reinforces the necessity to THOROUGHLY troubleshoot and not assume or take shortcuts...Wasn't there any code for the low fuel pressure?
On the subject of coffee, I've got a CC1 and VarioI use a stove top espresso just to be safe.
Bill
