bodine465
- May 6, 2004
- Gig Harbor, Wa
- 2015 XLT, 2002 Limited
So I have a bit of a headscratcher going on. I've been letting my daughter use my 2002 Explorer for a few months. Has around 170,000 miles on it and has always run fine. Couple of months back, she calls and tells me that she's at a friend's house and the Explorer will crank, but not start. Tracked it down to a blown fuel pump fuse #26. Replace the fuse and we're back on the road.
Last week she calls and says the car won't start again. Checked the fuse and it's fine. Replaced anyways and still won't start. Swapped out fuel pump relay, just in case, but nothing. Have it towed home and start playing with it. Find out that the fuel pump cutoff sometimes causes issues and try it. Thought I felt a click, but wasn't paying enough attention. Started right up and all is good again.
Fast forward to today and she calls again. Car won't start. Checks fuse, it's good. Presses the cutoff switch but still won't start. I head her way to try to figure it out and she calls just before I get there. Car started and is running fine again. Told her to drive it to my place so I can figure it out.
That's where I stand. Thought it might be a bad fuel pump, but it runs perfectly once it starts. Also fires right up when it's not being a PITA. Haven't changed the fuel filter in forever, but again, it seems like that would affect the way it runs, in addition to starting. Can't even rule out that the cutoff switch was the issue the second time, since I'm not sure it actually reset. Could have been just the down time while being towed, just like the down time from today. Any ideas?
