fuel issues | Ford Explorer Forums
fuel issues
gfoster
88 4x4 Ranger Supercab
I need some help. I'm trying to get an 88 Ford Ranger running. When I turn the key the fuel pump does not come on, I installed a new fuel pump in the tank, tested and replaced all of the relays (fuel pump, and EEC), checked the fuses, traced all of the wires, and even installed a test noid in one of the fuel injectors to see if it they were working. Nothing works! I can spray starting fluid in the intake and the truck will run for a few seconds. I've been able to ground out the red wire on the fuel pump relay causing the fuel pump to come on, it runs for ten seconds then shuts off, still nothing on the test noid. I've replaced the engine computer with another computer that has the same id numbers still nothing. where do I go from here? G
