fuel leak after fillup now stalling while driving | Ford Explorer Forums
satyr64
Washington DC
02 XLT
2002 fuel leaking out of canister vapor valve solenoid after fillup. did not top off. Now car stalls while driving
thanks for comment. I checked the pressure regulator on the fuel rail like you described and no fuel came out. I even turn the key on few time to pressure the system and started the car and nothing came out of the vacuum line on the regulator. As of now i think some how the gas pump over filled the tank and it backup liquid fuel into the evap system and when the pcm told purge valve to open instead of vapor, it flooded the engine cause it to stall. after 4-5 stalls i think the evap was purged of liquid gas.
follow up. I just changed the Vapor Canister Vent Solenoid near the tank. The original would allow air to pass when power on, new one did not. Hope this was my issue.
