Maxmax19773
- March 6, 2020
- Location
- Galleria
- Houston tx
- 2002 explorer sport 4.0
Hi . I removed the cluster trying to replace bulb and socket to make check engine light work but playing with different bulbs and sockets it did not work. I put everything back together. I try to find a good used cluster on eBay or local junk yards whenever I have time. I drove it today for 8 miles trip. It stalled couple of times, 2 times while driving and twice at idle. I also heard spark knock few times while accelerating. Is there anything else I can do or should I concentrate on fixing check engine light first? I will have some time next week to work on it. Is spot truck and explorer sport 2 doors have same cluster? They looks kind of identical. Don’t want to buy something that not fit. Thanks. MaxI was just asking if the cel is illuminated when the truck stalls… if it’s on then you have power to the computer
If the light is not on then it’s likely you are losing power to the computer… which is why we checked fuse 19
If 19 had corrosion on the pins then it’s likely the rest of them in the interior fuse
Box do too …
