fuel problems | Page 2 | Ford Explorer Forums
fuel problems
I heard a guy bragging about how he hasn't changed his oil in 60,000 miles. "The thing is still running". Thats pretty cool. I guess.
I wouldnt brag about not doing maintenance on a vehicle. that is shortening the life span of the truck...most def
I was mocking someone from where I work (though It wasn't the first time I heard that kind of thing). On maintenance procedures I have OCD. I just hope that this OP will come to a conclusion and save them some money.
If you have 6 wires on you MAF harness instead of 4 your IAT is in there also.
Don't know about the most def part. I know a guy a 1/2 ton with a 300 that NEVER changes the oil. Top it off yeah but a change for get it. The truck has 260,000miles on it. Only maintenance done was PCV,radiator clutch and u joints. I know because It's my Dad's truck and I did the repairs to it. I'm all for regular changes and using synthetics and i think he does it just to spite me. That truck runs damn good though.
ok....so i checkerd the fuel pressure and its not bad. i thought it might be the fuel pump but the pressure is coming out to just a little below spec.
If it is below spec it is weak. It will only keep going lower.
fixed!!!!!
:monkey: ok. so i sent it to the ford dealership and they said the fuel pump was hosed. it is a :can: canadian made explorer so i had to get the fuel pump that puts out 60+ psi 214 bucks OEM. fuel pressure regulater was hosed. got a new one. Egr valve was not holding pressure. got a new one. also changed the fuel filter ,air filter,and minor tune up. all in all its rollin fine now:burnout:
