Fuel Pump Relay | Ford Explorer Forums
Fuel Pump Relay
TLoren
Chicago, IL
'92 Explorer
Can anyone tell me where the fuel pump relay is located on a 92? All of the manuels I have and from everything Ford has told me, it should be in the Power Distribution box...but in earlier models, such as mine, the PDB only has fuses in it. There is a 30A fuse to the fuel relay but nobody seems to know where I can find the actual relay.
The relay is below the power dist box, it all comes apart with a flat head screwdriver.
there are likely 3 relays.
1 is EEC power (or power for the engine computer) Green
1 is the fuel pump relay (brown)
and the other is the air conditioning wide open throtltle relay.
If you are hav ing fuel pump issues you should also check the inertia switch which is behind the carpet under the glove box.
good luck!
