zhanx
- April 6, 2004
- Up state NY
- 2000 xls
Ok back at this. Time to do some work on it.
Ok checked it out.. other than one major issue that will require a hammer i think this can be done easy.
Recap : Raising the Gas Tank up after a body lift to help prevent a little damage and make it easier to skid plate.
As my tank is fuber on the bottom a little more hammering on the top wont hurt. I will be dropping the tank Sat. Doing measurements and pictures. I am going to try for a full three inches of lift on it. If not then 2 is fine.
The Plan use 3 inch spacers out of square stock cut down and welded back (unless i can get 2x3 free). So far it looks like i'll need to for the front and two for the back. Gonna make 10 spacers just in case.. might be over kill but oh well. gonna make 10 of the 3x2 and 2x2.
One more issue is going to be the lines running on the inside of the frame. Hopefully I can work around them or get access to put them inside the spacer if need be.
Any thoughts or ideas. go for them. (dont ask for pics yet cause i aint started. go out to your truck and look under it, thats better than a pic anyways)
