Gas Tank Thread
wattsgame
Paris Texas
got an idea for ya on this. remove the tank and throw it away!!!
go to the junk yard or neighbors yard that owns a bronco 2 and still the tank that sits behind the rear dif and fab some brackets and install it in your x where the spare tire use to sit. my 2 cents
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
zhanx
Up state NY
2000 xls
whats the capacity of the b2 tank? Will i have to change out fuel lines, fill hoses and rewire the fuel pump.. those questions are easy answered but seem like more work and cost more. ya i know it costs to play. but i figured it would be easier to lift it up and throw a skid plate over it.
Bronco638
Nobody Home
Itasca IL
'96 XLT 4.0L OHV
I've been kicking around this idea for some time now. Actually, there are quite a few phenolic Zeep tanks that will fit behind the rear axle and hold more than the B2 tank. Additionally, there are skid plates to go with those tanks. I believe the issue here is the way the fuel system works. As far as I can tell, there's a supply (to engine) and 'return' (to tank from engine) as well as some vapor ports, too. I don't think it's as simple as swapping tanks.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
My 99 Limited chassis is bare now. I will take a couple of pictures of the gas tank, but I think that there are a few items keeping it from being raised.
Sectioning the tank might be a more feasable idea, if the plastic could be properly fused together.
Don
Creager
Charlotte, NC
'92 Sport 4x4
i was thinking about this last night
what if it cut a section out of the top of the tank, to clear the cross member to raise it up? I'd probably loose a gallon or 3, but it might be the most cost effective way.
zhanx
Up state NY
2000 xls
Don
Don do you have a body lift? when i did the body lift i was looking around under it, the only thing i saw was the crossmemeber.. it was in march and i was home on leave (which makes everthing fuzzy due to the amount of alchol intake). I got my return date pushed back now, i wont hit stateside till mid to late june, maybe july but when i do get back, it will be done, anyone near NC got a metal break so i can bend the metal easier?
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
zhanx said:
Don do you have a body lift? ...
No, my 99 chassis is separated because I am soon going to drop my 93 body onto it. I am about finished with any work that I can do before the swap.
Don
A Extra Gas Tank Install Modified Explorations 9
H Can this gas tank trick be applied to Explorers? Modified Explorations 11
T Side protections & gas tank protection Modified Explorations 7
aldive Larger gas tank for an Explorer Modified Explorations 8
Rhett adding 2nd gas tank Modified Explorations 5
Trckmagik Jeep gas cap mod on Explorer Modified Explorations 26
L Do flowmasters improve gas mileage Modified Explorations 4
Scott B. Jerry (gas) can - plastic or metal? Modified Explorations 2
A Horrible gas mileage..11MPG Modified Explorations 13
M Gas mileage problems help! Modified Explorations 17
4 Billet Gas Doors and Exhaust Tips Modified Explorations 0
O Gas Gauge Modified Explorations 2
N drilled airbox improving gas mileage! Modified Explorations 16
B 93 X gas mileage Modified Explorations 1
A i relocated the gas pedal(?).."HOW TO" inside with pic's Modified Explorations 14
A moving gas pedel(?)? Modified Explorations 8
O Gas Mileage Modified Explorations 4
M What gas containers are safe to attach to roof basket? Modified Explorations 4
Brandons NATURAL GAS EXPLORER Modified Explorations 22
C What mods should I make to imoprove gas mileage? Modified Explorations 14
C Swaping Gas tanks Modified Explorations 4
E Gas Economical Lift & Tires but Beefy Look Modified Explorations 6
R Gas mileage Modified Explorations 0
T bigger tires how bad of gas milage? Modified Explorations 4
aldive Shift kit and gas mileage Modified Explorations 6
C Performance Mods that won't effect the gas mileage or improve it. Modified Explorations 7
9 Any mods to improve gas mileage? Modified Explorations 15
aldive Gas mileage with lowered Explorers Modified Explorations 11
aldive Air Dam and gas mileage Modified Explorations 4
A Gas Milage Question Modified Explorations 0
L Gas milage on new gears Modified Explorations 12
A Extra Gas Modified Explorations 2
Q Gas pedal question Modified Explorations 13
O gas mileage Modified Explorations 2
S Does KKM help gas mileage?? Modified Explorations 12
U gas and power questions Modified Explorations 13
M gas mieage??? Modified Explorations 1
A Gas Milage Problem Modified Explorations 10
M gas mileage Modified Explorations 2
N 1993 XLT Gas Mileage Improvement Project Modified Explorations 6
D Better Gas Mileage Modified Explorations 6
E Rear Tire/Gas Can Carrier to fit stock bumper 95-97? Modified Explorations 8
L In Tank Fuel Pump Question Modified Explorations 7
T Forced air intake from CO2 Tank? Modified Explorations 38
F Additional fuel tank capacity? Modified Explorations 2
S Onboard Air tank & tools Modified Explorations 6
B AIR TANK! Modified Explorations 4
Brian1 Air Tank Question Modified Explorations 36
T Bigger Fuel Tank? Modified Explorations 5
MONMIX My Bama thread part too Modified Explorations 2
Similar threads
