43R1c26
- February 8, 2008
- Stockbridge, Ga
- 93 Eddie Bauer
So my neighbors car started to run hot while I was driving it. I took the lower intake manifold off and seen that it had warpage so I replaced that big gasket. Put everything back together and it started right up but I was still getting white smoke from the tailpipe.
So I went and took the engine completely out to re-gasket the whole thing (even put new Cylinder head bolts). While it was out I took a tensioner off the camshaft/crankshaft timing chain but I never removed the chain b/c I realized a split second later that I was not removing the pistons. so I simply put it back. (I mean I truly didn't move the chain) I even checked for top dead center and mark alignment before putting everything back together.
Now that i'm trying to get it to start, it wont. Not even with starting fluid. I have spark,fuel, and of course I'm led to believe air. it seems every connection is connected properly. My firing order is correct.
So any help would be great
