Gears | Ford Explorer Forums
Gears
994x4Sprt
Anderson, SC
'99 Sport
How can you find out what gear ratio is in the rear-end? and also what's the biggest tire size that you'd go without changing gears? IF possible I'd like to get that for all the factory gear ratios b/c I'm not sure what gear i have....thanks
Wellcome
Put on your Helmit :eek:
the door sticker...find it, look under axle, look it up on by useing the search feature. I have 3.27's and run a 31...it's ok on road but offroad i'd like it abit lower. I'm going to be running 35"s once my sas is done and i'll have 5.13 gears
good luck
cp
Where is the sticker supposed to be at on the door? I have a caution sticker talkin about changing tire sizes and what not and then there's a white sticker but it doesn't say anything on it.......???
There is also a metal tag on the differential cover that has the gear ratio punched on it.
Thanks I appreciate the help. :thumbsup:
On the tag that's on the differential cover the number says 4 L 10 8 8 .......does that 4L10 mean I have 4.10's Limited Slip???
