kj4kym
- August 17, 2009
- Kingsport Tn
- 96 XLT Control Trac 4WD
so my truck has been running like total !@#$ lately. and so i finally got a day off to scrounge around under the hood. didnt see anything wrong by eyesight. also was wondering why it wasnt throwing the cel or anything codes? well come to find out the cel bulb was out. and when i hooked on the obd II code reader heres what it has showed. ready for this....
p0153
p0401
p1151
p0303
p0304
p0306
i belive that the first is a o2 sensor
2nd is the egr valve
not sure about the 3rd
but 4th 5th and 6th is cylinders 3, 4, and 6
i was just wondering if anyone has had one throw all of these codes, and found a fix.
i tried to fix it but money is tight and i cant just buy parts to try, but heres what i have put on so far.
6 new plugs and wires, might pull the plugs back out and take another look since its been a month or so, and yes before you say it, yes i did check the gap of the plugs. lol
also put on a new distribtor cap or whatever its called on here.
tried a new heat sensor thing, its right under the intake manifold, little brass piece with a 2 wire connector.
may try the camshaft position sensor tomorrow, heard it could be a source of misfire.
but as of right now im kinda at a loss, im really looking for people to point me in the right direction. and what parts i should look at.
oh also i was going to check the fuel pressure today, but when i put the gauge on it started leak gas where the crimp was on the hose. so dont but the harbor freight fuel pressure gauge cause its JUNK!
HELP!!! ANY, AND ALL thanks
p0153
p0401
p1151
p0303
p0304
p0306
