getting codes in instrument cluster test mode | Ford Explorer Forums
xvprflyboivx
Tobyhanna, PA
'03 XLS Sport
getting DIAGNOTIC TEST CODES in instrument cluster test mode
can anyone tell me what these codes are/mean?
dtc - d262
dtc - 9318
dtc - 9352
dtc - 9201
if anyone has the information on these codes, can you please tell me what they are. i have put my instrument cluster in test mode before and ive never seen this goin thru the different tests.
thanks in advance.
*i think i found out what "dtc - 9318" means (battery voltage is low) & "dtc -d262" (ive read its a common code and not cause for concern). does anyone have any information on the other codes? i've searched and searched and searched and found little to nothing that applies to this... my gas is being eaten more than normal and i am a little concerned. surely someone in this forum must know what these codes mean
Cant tell you what those codes mean, but from what I have read on this site, the test mode for the cluster wont give you information/codes about engine related things such as O2 sensor or a misfire.
It only for diagnosis of problems with the cluster itself.
Correct...only shows problems with cluster or problems with inofrmation sent to the cluster...like low battery voltage or low oil pressure.
Here's what I found for information on instrument cluster test. It explains each item scrolled in more detail.
