torinoscj429
- December 3, 2009
- San Diego
- 2000 Mountaineer V8 2WD
Gotta LOVE these electrical gremlins!
I have a 2000 (built 11/99) Merc Mountaineer Monterey. I did some troubleshooting with the balky driver side door lock actuator, and still haven't got 100% function out of it.
Inside the car: push down on D/S LOCK button, 3 doors and liftgate lock, D/S does not lock.
Inside the car: push down on D/S UNLOCK button, 3 doors and liftgate unlock, D/S does not unlock.
Outside car: Keyfob lock, 3 doors and liftgate lock, D/S does not lock.
Outside car: Keyfob unlock, ALL doors and liftgate unlock.
Outside car: Keypad lock (7/8 + 9/0 simultaneously), 3 doors and liftgate lock, D/S does not lock.
Outside car: Keypad unlock (code + 3/4), ALL doors and liftgate unlock.
I took apart the door yesterday, and tried a known good actuator, and got the same results. I disassembled and traced the wires to the big door jamb connector, and found no fault with the door wiring. The wires going into the vehicle would still only UNLOCK the known good actuator.
Knowing that the wires act as positive and negative alternately, getting the thing to UNLOCK should also get it to LOCK...since there are only TWO wires to the actuator, the same wires just switch polarity to change direction.
Since the D/S door will UNLOCK with the keyfob and/or door keypad, this leads me to believe that the wiring is ok.
What should I look for now?
Thanks,
Gerard
Thanks,
Gerard
