02explode
- March 18, 2013
- 2002 explorer 4.0 4x4
Hey you guys. Newbie here. I am an old school mechanic(carbureted cars and trucks) and this new computerized stuff seems like a fun challenge. I recently got a 2002 explorer that runs great, with the exception of the fact that the transmission doesn't work. It is a 4x4, and I checked the fluid today, and it is really low. I jacked up the truck level and checked the fluid in the drain plug with the engine running, and it had like 1 drop that came out. The line pressure is definitely high, as I can hear the pump whine like a baby when it is running. The check engine light is not on yet, so I think the previous owner shut it off before frying the tranny. Also have the infamous "O/D off" light blinking, so there is a tranny code stored in the computer.
Got a couple questions:
1. I can't drive this thing anywhere, so what's the cheapest way for me to pull the codes in the computer for the trans.?
2. Is low fluid enough to throw a code in the computer?
3. I don't see any trans. fluid leaking anywhere, except at the cooler where the lines connect in the front, by the radiator, so where did the fluid go?
4. can I disconnect the battery, and do a simple body ground reset to clear the codes?
Thanks in advance guys...
