kturnerga
- August 4, 2008
- GA
- 96 Ranger XLT 4.0 Ext cab
I have a 1996 Ranger 4.0 Extended Cab. It has a estimated 200,000 miles on it (estimated because the odometer died some time back). I acquired it three years ago and have been working on it since. I drive it once every week or two.
I am happy with the truck and love the work I've done on it. Being that it's gotten 200K miles is there any more that I need to look out for?
Other than the normal maintenance I've done the following:
Power-sprayed the underside
Had the A-bracket replaced on one side
Replaced tie-rod and ends
Aligned front end twice
Painted frame with bed removed and painted drive shaft, axles and brake drums
Installed new stereo and rewired speakers
Had an induction cleaning
Replaced brake pads on front
Replaced fuel filter
Overhaul of transmission and replacement of shifter cable
What remains to be done:
Fix issue with steering slop
Paint exterior
Deal with timing chain rattle sounds (much later $$$)
Replace broken windshield
Again is there anything else to consider?
KT
Paint exterior
KT
