Grille and headlight exchange | Ford Explorer Forums
E r i c
First off, if this is a redundant question I apologize. I know it can be irritating to answer the same question over and over again. This is my first time on, I have done several searches, looked at the new member info, looked at FAQ, etc, and could not find the information I seek.
My daughter's 1999 Explorer XLT is in need of some front end parts thanks to her not listening to her Dad about driving rules. Fortunately no people or animals were injured, but the front end of her truck sure was.
I drove about an hour to purchase a grille from a Craigslist 1999 Ranger, and was disappointed to find it did not match the Explorer. Dumb me, I assumed all 99 Exlporer, Mountaineer, and Ranger trucks had identical front ends. They would if I was in charge of FoMoCo, but hey, that's another story.
So, my question: when searching for replacement parts (grille, headlight assembly, turn signal assembly, fender, etc) which models will have the correct replacement/exchange parts? Can I assume all 1995-2001 Explorer parts will work? Can I assume all 1995-2001 Mountaineer parts will work? Will any Ranger parts work, other than the fender? Thanks.
Eric
98-01 Mountaineers had different front ends. So stay away from those.
Your front bumper was available on 99-01 Explorers.
Grille/headlights should be 95-01 Explorers.
Good luck!
i call this a time to customize! why not swap the parts with a better looking version like people do with explorer to mounty's... then again if you liked the explorer front, more power to ya!
There is a lot more involved than you think to do so. The header panel has to be changed as well for the 99-01 Mountaineer headlights to fit.
AGREED. Seems like overkill to do a Mounty conversion if all he's trying to do is fix the Explorer up for his daughter.
She'll just wad it up again.
Hey, Im new on here and have been looking for a billet grille from my 2003 mountaineer, does anyone know if i can use an explorer billet??
it might fit upside down...
go find an explorer in a parking lot and park next to it and take some measurements. if its bigger you're golden because you can trim it to fit
*EDIT* that only works for 98-2001... you're in the wrong forum
