Erika
- August 29, 2008
- Orange, CA
- 2001 XLS 2WD
Alright, as if the overheating wasn't enough, now there's something else. About 3 weeks ago, I replaced the front brakes on my '01 Explorer 2wd. The rotors were warped so I replaced them, too, as well as did my first regreasing of the bearings. Everything went very smoothly, I've done many brake jobs, but now, very sporadically, I get a kind of grinding noise when braking a little more than gently. Sounds like when you've ground your pads into the metal, not quite so loud. There's a faint smell, like hot grease, too. Thought things were coming apart, so I tore it down again, but all the bolts are nice and tight, rotor isn't getting damaged, I can't see a darn thing that looks out of whack. Thought maybe I tightened the axle nut too much, so I backed it off and retightened, (I know it doesn't take much) Looked like problem solved but I just heard the darn noise again coming home today. Seems to happen during braking on long downhills, that's the only time I've heard it. Noise is on both driver and passenger. Any ideas?
