xplorernewb
- May 6, 2014
- washington state
- 91 ford explorer sport
so im having a bit of a clutch problem. it grinds when my foot is on the clutch, while it being in 1st or 2nd, usually downshifting coming to a stop.
the master cylinder had been leaking at the top of the hose connected to the res so i put a clamp on it and it worked, and bled the system. i also fixed the shifter bushing today and it shifts SO much better. almost like brand new gears again, but its still grinding. it seems like its fully disengaging, it catches near 3/4 to the top of the pedal, shifts nice and smooth even half way.
it doesnt do it every time though.. im going to try replacing the fluid in the transmission, but if that doesnt work, what else could it be?? i can also hear a lot of bubbling in there but i have the boot removed for the moment.. it bubbles a lot more when it starts grinding, and goes away as soon as i pump the clutch or throw it in neutral. it does this when its cold and hot.
