grinding | Ford Explorer Forums
grinding
devilbunny13
san antonio texas
02 ford explorer sport
I was hoping someone can help have 02 X sport the problem im having is when I stop something up front sounds like grinding..I have new rotors/pads/calipers/bearings/outer tie rod ends/ & bearing seals///also slight pulsaating when stopping...thank you in advance for any advice.
If I had to guess it could be a bad ABS sensor in one of the bearing assemblies, causing your ABS to activate at a slow speed.
