Big Bear Bob
- April 20, 2002
- Big Bear area of Southern Ca. near "Rim of the World drive", & Sugarloaf Mountain
- 98 XLT /01 Dodge 1500 4X4
So it's just a matter of bigger tires? or Is there a way you can put blocks or something under the axle to gain more clearance?
Because even with a TT and Shackle lift I understand you can sqeeze 32's on your X but they will rub. Then 32's will only give you a half inch more ground clearance to the rear diff. I know every inch counts, but beyond the TT Shackle lift I haven't heard anything other than trying to fit 32's under your truck to gain more clearnce. I just pulled the plate loose on the rear differential, and would love to find away to gain a little more clearance without busting the bank, and inch might do the trick
