(Guide)98-01 Mounty Headlights/Front End to 95-01 Explorer | Ford Explorer Forums
laxattack
Wilmington, NC
1996 XLT AWD
Ok, since there wasn't really a guide for this I thought I would go through a quick rundown since I just did an HID Retrofit into them.
Parts Needed:
95-01 Explorer
Headlight Top Cover(or what ever it's called) from 98-01 Mountaineer
Header Panel from 98-01 Mountaineer
Headlights from 98-01 Mountaineer
Corner Lenses from 98-01 Mountaineer
Grill from 98-01 Mountaineer
10mm Socket
8mm Socket
13mm Socket
2-4 hrs+ of your time depending on the rusted bolts :-D
Step One:
Remove all Screws/bolts that attach the grill and headlight top cover
Roughly about 6-8 screws and bolts
(sorry no pics)
Step Two:
Unscrew bolts holding Turn Signals/corner lenses and remove them. Once removed, take grill off header panel (pull gently don't break the clips)
(once again no pics)
Step Three(the fun part):
Unbolt all bolts holding in Header panel and remove plastic radiator panel cover.
(places where bolts are at are marked in red)
The ones behind the fender are a P.I.T.A.! make sure to either remove the fenders (this is the hard way), or Remove part of the wheel well cover to gain access to them
Step Four:
Remove Header panel
Step Five:
Place "new" header panel on to car (reverse steps of step 3)
Step Six:
Install "new" Grill
Step Seven:
Install Mountaineer Headlights into Header panel (make sure to align them at this point that was a bad mistake for me)
Step Eight:
Install Mountaineer Corner Lenses
Step Nine:
Install Headlight Cover panel thingy
Step Ten:
Crack open a beer (if of age) You are done!
Before
After
I still Need to do work to the grill (or just may buy another one)
Nicely done... Lots of people ask about that one... :thumbsup:
Thanks for the guide! Now, I know how imma do mine now. BTW, where did you get your projectors and halo from?
Projectors are morimoto h1 from the retrofit source, and the halos are from unmitza.com
Alright cool, Thanks you very much!
00 mountaineer headlight set up
I have a 00 Mountaineer looking to trade front end from Mountaineer to explorer If you have one in good cond and looking to upgrade to 00 mountaineer from your 95-01 explorer Please let me know I got a after market chrome grille and new head lights, I hit a deer in November had to replace it all. I live in PA Thanks Mountyrob
mountyrob & all. Any talk of sales or trades should only be by Elite members (or done in PM).
If you have any questions, please let me know.
hey when you switched from the explorer to mountaineer grille, what did you do for the wiring harness? did you splice in a mountaineer harness?
What do you mean about the wiring harness. All the bulbs I had fit in the mounty housings
