Pdwight
- December 5, 2005
- North West Alabama
- 94 Limited
I had my 94 Explorer hood up sat marning and after a recent power steering change (by the dealer $$$) I had a lot of build up on the side of the engine from the year of slowley leaking fluid. So I used foaming engine cleaner (cold engine) and let it set for 30 minutes and sprayed it off with a small 110 pressure washer and it came very clean. I let it set another hour before starting it up to warm it up and dry it out....it started instantly and ran fine. I let it warm completly up and closed the hood and test drove it .....now it doesnt want to come out of first gear when its cold, after it warms up its fine. I checked the Auto fluid and its fine and all pink and new looking from the $2K job less than a year ago at a Tranmission place. Anything I am missing here, any clues ?? ...........it did not do this before I washed the engine ??? I parked it over clean dry concrete over night to look for any leaks and there are none....just biouncing this off you guys (and gals if here)
Thanks
Dwight
Thanks
Dwight
