This is how I removed mine...
Loosen the harmonic balancer bolt, the bolt should have about 10 threads left engaged with the crank....
And I know the following is going to sound weird, but just do it....
Remove a few of the bolts that are used to bolt the A/C compressor to A/C compressor bracket, and use THOSE bolts to go through the cast steel puller, and thread them into the balancer. The A/C Bolts are the perfect length, and the right thread size/pitch.
For pressing the balancer off the crank, use the 'flat' or 'top hat' shaped end on the center "pressing" bolt.
Place the flat end against the head of the harmonic balancer bolt.
Start turning the BIG bolt....
Eventually you will have to remove the balancer bolt as it will bottom out on the bolt before falling off the snout of the crank, but that iwll get you started, and you SHOULD be able to figure it out from there. If you can't figure it out, you PROBABLY shouldn't be swapping out your own timing chain.
Ryan
