mesome
- November 24, 2009
- Kansas City, KS
- 2000 Sport
First off, I have say the volume of information on here regarding this issue has been extremely helpful. Thanks to all the people who were kind enough to document this stuff.
Vehicle info:
2000 Ford Explorer Sport
178,000 miles
4.0L V6
Transmission Door Code: D
I started getting the 2-3 shift flare this past Sunday, it was jumping up 1000+ RPM's under acceleration before shifting into 3rd and right before I made it home the O/D light started a steady blink and I had to manually use the column shifter to get it to shift. (Limp mode?) I drove it to a local transmission shop on Monday and asked them to look at it. Unfortunately the guy who owned it before me screwed up the wiring on the diagnostics plug-in so they couldn't read any codes for it, but after we drove it down the street and back the guy told me it would have to be completely rebuilt. ($1800+)
That night I found and read through the rebuild diary a few times and some of the other sticky threads.
Since then I've driven it around some more, making sure to always back off the gas before the 2-3 shift (around 25 MPH) and it's behaved a lot better than it did on Monday, no more blinking O/D light. Right now it seems to be shifting fine most of the time, even under mild acceleration. I'm not having any issues with reverse or any other gears like I've seen others mention on here. Obviously I can't leave it like this, so I've decided to pull the valve body and see what I can find but before I did that I wanted to ask a few questions on here just to make sure I had my information strait. So enough of the rambling, here are my questions.
1. Everything I've seen says I have the 5R55E transmission. (see vehicle info above) True? (is there another easy way to confirm this?)
2. Assuming 1 is true, I'd prefer to buy a rebuilt valve body and install it rather than rebuild the one that's in there. Is there any reason not to do this other than cost?
3. I've seen a few people link to this valve body http://www.800700tran.com/prod.itml/icOid/80 Why is it so cheap when Ford wants $100+ for just the EPC solenoid? Is Ford bending us over on price or are the new parts on that rebuilt one lower quality? (AKA, am I safe buying it?)
4. I've never changed the fluid or filter in the one year that I've owned it, should I have it flushed before replacing the valve body or is it better to just replace the fluid that was lost while replacing the VB?
5. If I don't buy the rebuilt valve body right away, would it make any sense to buy a new EPC solenoid and replace it to see if that's the root of the issue? (Can that be replaced without removing the valve body?)
Anyway, thanks in advance. Hopefully I can get this fixed and avoid that expensive rebuild.
Vehicle info:
178,000 miles
4.0L V6
