Steve Castlebury
- July 26, 2018
- Chester Va
- 1998 Explorer Eddie Bauer
Just purchased this explorer and I am having issues with it installed a new battery and starter because it would not start when I bought it after I put the starter in and tried to start it nothing happened again so i checked all the fuses all good after that I accidentally locked myself out of the truck with the hood open tried to get in the back door and the alarm went off so I disconnected the battery waited about 10 minutes hooked it back up and the alarm system is still going off so I used a long rod through the passenger side window to open the driver's side door putthep key in the ignition and then hooked the battery back up it sounded like it reset no horn going off and when I tried to start it started right away that was yesterday today it will not start again is there something I'm doing wrong any help appreciated
Thanks Steve
Thanks Steve
