OK, I cannot hold my piece on this any longer. Some of you who live in Europe, not sure about down under, may be able to support what I am going to say here.
I lived in Germany from 83 to 89 and had several vehicles and various types of stereo equipment. HD radio is a marketing gimmick here the Good ole US of A. All of the adds that tell you there are "high definition" stations between your already used stations on the dial (or display) are really pulling your leg, and at your wallet.
Europe uses and has used the even numbered frequencies for decades and decades. In the United States we use the odd numbered frequencies, and have for decades. Analaog radio waves travel through the air in the same manner, especially between 88 fm and 108 fm, regardless of it being an odd or even number.
I had an old Apline head unit that I purchased in Germany that recieved "HD" signals until it was stolen out of my BII a while back.
The marketing machine is doing a really good job of selling High Def radios though. Now, when you are referring to Sirrius or the other Satellite radio system(s), it is a different story. Those recievers are getting a digital signal which is then converted to analog so it can be piped into your radio through the antenna feed. The difference here is that the signal fed is cleaner because it is digital. The signal on the even banded "HD" radios has less interference from other broadcasts so it is margianlly cleaner. The problem is, once there are as manny "HD" stations as analog stations the same old problem will exist, frequencies will interfere with each other.
Just my thoughts on throwing away your hard earned dollars...
