BubbaFL
- June 8, 2007
- Central Florida
- 1986 Corvette
I'm getting ready to put my SOHC back together and have a couple questions:
#1 - Is this stuff good to use on the headgaskets? permatex copper spray a gasket
#2 - Would that stuff be good on the exhaust manifold gaskets? The stock gaskets were thin metal pieces (several on each side). The new exhaust gaskets are some kind of plastic / composite.
#3 - When I'm finding TDC on the number 1 cylinder to set the timing, how precise does it need to be? The crank turns several degrees with no apparent piston movement - do I want to be at the beginning, middle, or end of that range?
Thanks!
Thanks!
