head gasket blown??? | Ford Explorer Forums
firefighter7127
Salisbury NC
1991 Eddie Bauer
hi,
i have a 91 eddie bauer explorer...it currently has about 112k miles. a few weeks agoi started hearing what i thought was an exhaust leak. took it to the shop after it started getting worse. turns out to be a warped/cracked exhaust manifold. when running u can see exhaust coming out from around the manifold. yesterday it started smoking badly from under the hood...looked like exhaust smoke (blueish in color) but i could smell a hint of antifreeze smell as well. well today on the way home..it started to overheat...so i pulled of the side of the road and it looked like whiter smoke and alot of it. i got it home and poured some water in it...it was about a gallon low. i let it warm up to the temp for the themostat to open...when it opened i could see steam that appered to be coming out from close to the exuast manifold as well as around the thermostat housing and water pump. there doesnt seem to be any leaks while the truck is idleing at a stop (as if from a water pump). it was steamy and kind of dark so i couldnt really tell for sure where it was coming from. there isnt any water in my oil and when i start my explorer whit the radiator cap off it doesnt bubble like a blown head gasket does. any ideas what this could be? any info would be appreciated. thanks!
Hey man I hope you don't have to go through what I did about a week or two ago, but it sure sounds like the symptoms my 92 explorer was having. It turned out to be a cracked head.
Doesnt sound good, but (just in case) check all fittings on you're Coolant hoses, check them for leaks, (been there, done that), and check anything coolant related to the exhst manifold leak, it could have gotten hot, and melted something. But most likely it sounds worse then that. Start with the small things, then if you are wrong, you arnt out alot. Heater Hose, and the like is dirt-cheap at a parts store. Also warm it up, to just about overheating, and park it on a concrete area, check the ground for the leaking and work you're way on from there. It could be a stupid hose, it could be a cracked head, who knows. I give you luck, and gods speed.
-Justin
thanks for the replys you guys...ima gonna get to cracking on it tomm. ill keep you updated on the progress....thanks again!
