Head lamp removal hepl. | Ford Explorer Forums
diesel22g
Rochester, NY
94' XLT 4x4
Can any of you guys post a step by step walk through to removing my head lamps on a 94 xlt. I'll be replacing them with new ones but i don't even know where to start to get the old ones out. I've herd you need to remove the grill and a bunch of other stuff so I need someone to set the record straight. It would be a big help guys, and a christmas miracle if I were able to do this sucessfully. Thanks.
Remove the grille, remove the corner lamp assemblies, there are 4 bolts per headlamp assembly, 2 on each side. Remove those and they're off.
There are about ten "bolt/screw" things holding the grille in...at the bottom of the grille are two compression fittings...you sort of squeeze those to pull the whole thing iff.
