gtyates
- September 24, 2002
- Location
- Tennessee
- Goodlettsville Tennessee
- '09 Sport Trac, '21 Explo
I have never had this happen before. I am trying to re-adjust my headlamps because I had adjusted them a little higher than I prefer. Using measurements to the center mark on the lense I attempted to get them down to where they need to be. The passenger side one adjusted with no problem, but the driver side is not cooperating. I was able to lower the drive side, but I went a little too low. When trying to bring it back up I can't get it to rise to where it needs to be, so the driver side light beam is now a little bit too low. Is it possible that the internal "gears", which I assume are probably plastic, have gotten partially stripped and that is why I can't adjust further? Anyone else had this happen? Any suggestions, other than replacing the entire housing?
