mu2bdriver
- March 7, 2009
- CT
- 2000 XLT
Greetings,
This afternoon I noticed that my right headlight was out when it was used on low beam - the high beam worked. I replaced the light and ops tested good...until I noticed that my fog lights, both of them, didn't work. When I pressed the console button the green light lit up but not light from the actual fog lights. I usually drive with them on all the time. I didn't notice if they were faulty before I did the headlight. I checked the fuse and it was intact, checked the light connector and it felt tight. Could both of them have gone out simultaneously or within a reasonable time and i just didn't know it or is there some common connection that I should check before buying new bulbs.
It's a 2000 Explorer XLT and this headlight is the first one I've replaced and I drive it at nighttime @75%.
Thanks in advance.
Thanks in advance.
