Headlights blinking | Ford Explorer Forums
Headlights blinking
Big_Kuntry
Baxley, Georgia
93 xlt
My headlights flash on an off when I have them on bright. but are fine when on dim and also are fine when i pull the Blinker switch back which makes the brights and dims come on.
Do they blink at a particular rate? When you hit a bump?
I've got an issue with my turnsignal stalk and the highbeam switch (connection), where occasionally the headlights do not come on until i "wiggle" the stalk, then they illuminate. I recently noticed that if i push the stalk forward to run the highs, they will flicker as if a connection somewhere isn't connected. Rarely do i use the highs so it hasn't been a factor.
No they dont they cut off and on and they only do it on highwhen the switch is pushed forward.
Sounds like a loose connection or bad filament, etc.
I had a similar problem but it only happend once and it went away my head lights started to blink on/off just like hazzards would. dont know what thats about.
altenators can cause a symptom like this
Repace the headlight switch,the one on the dash I had the same problem, the switch would feel hot.
